The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
gpo.security events
Creating your file...
Your file is ready
gpo.security.unrecogFileForm
- Severity
ERROR
- Description
This event occurs when the GptTmpl.inf file is not in UNICODE (16 bit)format.
- Corrective Action
Ensure the security file GptTmpl.inf is in UNICODE 16bit format.
- Syslog Message
Security file is not unicoded.
- Parameters
filename (STRING): The security filename.
gpo.security.unrecogTemplate
- Severity
ERROR
- Description
This event occurs when the system fails to recognize the security template.
- Corrective Action
Ensure the security file GptTmpl.inf has the correct header.
- Syslog Message
Unable to recognize the security template.
- Parameters
(None).
