gpo.security events
gpo.security EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) security template file format.
gpo.security.unrecogFileForm
- Severity
ERROR
- Description
This event occurs when the GptTmpl.inf file is not in UNICODE (16 bit)format.
- Corrective Action
Ensure the security file GptTmpl.inf is in UNICODE 16bit format.
- Syslog Message
Security file is not unicoded.
- Parameters
filename (STRING): The security filename.
gpo.security.unrecogTemplate
- Severity
ERROR
- Description
This event occurs when the system fails to recognize the security template.
- Corrective Action
Ensure the security file GptTmpl.inf has the correct header.
- Syslog Message
Unable to recognize the security template.
- Parameters
(None).
