ONTAP EMS reference
gpo.security events
gpo.security EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) security template file format.
gpo.security.unrecogFileForm
Severity
ERROR
This event occurs when the GptTmpl.inf file is not in UNICODE (16 bit)format.
Corrective Action
Ensure the security file GptTmpl.inf is in UNICODE 16bit format.
Syslog Message
Security file is not unicoded.
filename (STRING): The security filename.
gpo.security.unrecogTemplate
Severity
ERROR
This event occurs when the system fails to recognize the security template.
Corrective Action
Ensure the security file GptTmpl.inf has the correct header.
Syslog Message
Unable to recognize the security template.
(None).
