migrate.root events
Creating your file...
migrate.root.completed
- Severity
NOTICE
- Description
This message occurs when the migration of a root aggregate has completed successfully.
- Corrective Action
(None).
- Syslog Message
Root aggregate migration completed successfully on node %s.
- Parameters
node (STRING): Name of the node that completed the migration.
migrate.root.failed
- Severity
ERROR
- Description
This message occurs when the migration of a root aggregate has failed.
- Corrective Action
Run the "system node run -node nodename -command aggr status" command to determine if the target aggregate named "new_root" has been created. If not, address the error condition and attempt the "system node migrate-root" command again. If the new aggregate exists, contact technical support to complete the operation.
- Syslog Message
Root aggregate migration failed on node %s. Reason: %s.
- Parameters
node (STRING): Name of the node that failed to complete the migration.
reason (STRING): Reason that the migrate operation failed.
migrate.root.started
- Severity
NOTICE
- Description
This message occurs when the user initiates an attempt to move the root aggregate to a different set of disks on a node.
- Corrective Action
(None).
- Syslog Message
Root aggregate migration started on node %s.
- Parameters
node (STRING): Name of the node.
