fci.link events
fci.link.break
- Severity
ERROR
 - Description
This message occurs when the Fibre Channel adapter detects a break in the link.
 - Corrective Action
If the adapter is in use, check the cabling.
 - Syslog Message
Link break detected on Fibre Channel adapter %s.
 - Parameters
adapterName (STRING): Name of the associated Fibre Channel host bus adapter.
fci.link.break.shelf.fw.update
- Severity
INFORMATIONAL
 - Description
This message occurs when the Fibre Channel adapter detects a break in the link due to a shelf firmware update being performed.
 - Corrective Action
No corrective action is required. This is expected behavior when firmware is being downloaded to a shelf.
 - Syslog Message
Link break detected on Fibre Channel adapter %s while downloading shelf firmware.
 - Parameters
fci.link.error
- Severity
NOTICE
 - Description
This message occurs when the Fibre Channel adapter cannot recover the link and the link is going offline.
 - Corrective Action
(None).
 - Syslog Message
Could not recover link on Fibre Channel adapter %s after %d seconds. Taking the adapter offline.
 - Parameters
downTime (INT): Amount of time that the link is down.
