ONTAP EMS reference
clam.update events
clam.update EMS events occur when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) updates the failover state of the partner.
clam.update.partner.state
Severity
INFORMATIONAL
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) updates the failover state of the partner.
Corrective Action
(None).
Syslog Message
CLAM on node (ID=%llu) updated failover state of partner (ID=%llu) to %s.
localnodeid (LONGINT): Node ID of the local node.
partnernodeid (LONGINT): Node ID of the partner node.
partner_state (STRING): Description of the partner state.
