clam.update events
clam.update EMS events occur when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) updates the failover state of the partner.
clam.update.partner.state
- Severity
INFORMATIONAL
- Description
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) updates the failover state of the partner.
- Corrective Action
(None).
- Syslog Message
CLAM on node (ID=%llu) updated failover state of partner (ID=%llu) to %s.
- Parameters
localnodeid (LONGINT): Node ID of the local node.
partnernodeid (LONGINT): Node ID of the partner node.
partner_state (STRING): Description of the partner state.
