disk.partner events
disk.partner EMS events occur when ONTAP encounters issues associated with disk operations on HA partner nodes.
disk.partner.encrRevertDone
- Severity
NOTICE
- Description
This message occurs when a node receives notice that a partner node has completed a disk encrypt revert operation.
- Corrective Action
(None).
- Syslog Message
The partner has completed reverting drive %s to its original state.
- Parameters
diskName (STRING): Name of the device.
disk.partner.encrRevertStart
- Severity
NOTICE
- Description
This message occurs when a node receives notice that a partner node has started a disk encrypt revert operation.
- Corrective Action
(None).
- Syslog Message
The partner has started reverting drive %s to its original state.
- Parameters
disk.partner.sanitizeStart
- Severity
INFORMATIONAL
- Description
This message occurs when a message is received from the partner for a disk sanitize start.
- Corrective Action
(None).
- Syslog Message
The partner has started a disk sanitize on %s.
- Parameters
diskName (STRING): Name of the disk.
