ONTAP EMS reference
disk.partner events
disk.partner EMS events occur when ONTAP encounters issues associated with disk operations on HA partner nodes.
disk.partner.encrRevertDone
Severity
NOTICE
This message occurs when a node receives notice that its partner has completed a 'disk encrypt revert_original' operation. Check the command status on the partner node.
Corrective Action
(None).
Syslog Message
The partner has completed a 'disk encrypt revert_original' operation on drive "%s". Check the partner node for the command status.
diskName (STRING): Name of the device.
disk.partner.encrRevertStart
Severity
NOTICE
This message occurs when a node receives notice that a partner node has started a disk encrypt revert operation.
Corrective Action
(None).
Syslog Message
The partner has started reverting drive %s to its original state.
disk.partner.sanitizeStart
Severity
INFORMATIONAL
This message occurs when a message is received from the partner for a disk sanitize start.
Corrective Action
(None).
Syslog Message
The partner has started a disk sanitize on %s.
diskName (STRING): Name of the disk.
