ONTAP EMS reference
fcvi.qlgc events
fcvi.qlgc EMS events occur when ONTAP encounters issues associated with FC-VI adapter firmware and driver operations.
fcvi.qlgc.async.event.overflow
Severity
ERROR
This message occurs when total number of async events are overflowed.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s async event overflowed. Resetting the adapter.
port (STRING): FCVI Interconnect NIC.
fcvi.qlgc.connErr
Severity
ERROR
This message occurs when the FC-VI adapter detects a connection error. The FC-VI driver will attempt to retry the connection.
Corrective Action
If this message repeats frequently, there may be an issue with the FC fabric or the adapter. Contact NetApp technical support.
Syslog Message
FC-VI adapter: Port %s detects connection error. FC-VI opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu. %s
port (STRING): Interconnect NIC.
opcode_str (STRING): FCVI opcode.
opcode (INTHEX): FCVI opcode.
qpname (STRING): QP name.
qpnum (INT): QP number.
systemID (LONGINT): Remote node's system ID.
info (STRING): Additional info.
fcvi.qlgc.cpr.reset.cancelled
Severity
ERROR
This message occurs when the CPR reset initiated by the FC-VI port got cancelled.
Corrective Action
Reboot the filer. If issue still persists then replace the FCVI adapter.
Syslog Message
FC-VI adapter: CPR reset initiated by port %s got cancelled. Offlining the port.
port (STRING): FCVI Interconnect adapter.
fcvi.qlgc.cpr.reset.failed
Severity
ERROR
This message occurs when the CPR reset initiated by the FC-VI port fails.
Corrective Action
Syslog Message
FC-VI adapter: CPR reset initiated by port %s failed.
fcvi.qlgc.cpr.reset.unsupported
Severity
ERROR
This message occurs when the CPR reset is not supported by the adapter.
Corrective Action
Syslog Message
FC-VI adapter: CPR reset is not supported by port %s.
fcvi.qlgc.FrameDiscardErr
Severity
ERROR
This message occurs when the FC-VI adapter firmware discards a received frame because of a receive frame error.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Discarded a received frame because of a receive frame error. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
qp_name (STRING): QP name.
qp_index (INT): QP number.
exchange_id (INTHEX): Exchange ID.
address (INTHEX): Address offset of the last good frame.
system_id (LONGINT): Remote node's system id.
fcvi.qlgc.hard.reset.failed
Severity
ERROR
This message occurs when an FC-VI port's soft reset fails.
Corrective Action
If CPR reset is not supported in the platform, then reboot the filer to recover from this issue. If issue persists then replace the FCVI adapter.
Syslog Message
FC-VI adapter: Hard reset failed at port %s.
fcvi.qlgc.invalid.data
Severity
ERROR
This message occurs when FCVI driver receives invalid data from firmware.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s received invalid data. QP index = %d, completion status = %s(status code = %d), opcode = %s(%d), remote node's system id = %llu. %s
qpnum (INT): QP index.
status (STRING): Completion status.
status_code (INT): Completion status code.
opcode_str (STRING): FCVI opcode in string.
opcode (INT): FCVI opcode.
systemID (LONGINT): Remote node's system Id.
fcvi.qlgc.invalid.exch.address
Severity
ERROR
This message occurs when FCVI driver receives a response with invalid exchange address.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s received invalid exchange address for %s. QP name = %s, QP index = %d, expected exchange address = 0x%x, received exchange address = 0x%x. %s
resp_type (STRING): Response type.
exp_oxid (INTHEX): Expected exchange address.
rcvd_oxid (INTHEX): Received exchange address.
fcvi.qlgc.invalid.qp
Severity
ERROR
This message occurs when FCVI driver receives invalid QP index from firmware.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s received invalid QP. Received QP index = %d, completion status = %s(status code = %d), entry type = %s(entry code = %d). %s
entry_type (STRING): Request/Response entry type.
entry_code (INT): Request/Response entry code.
fcvi.qlgc.invalid.response
Severity
ERROR
This message occurs when FCVI driver receives invalid response from firmware.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s received invalid response. %s. %s
error_type (STRING): Type of error.
fcvi.qlgc.ioErr
Severity
ERROR
This message occurs when the FC-VI driver receives some IO error.
Corrective Action
No corrective action is required. The driver internally resets the adapter if required. However, if you see this message frequently, there might be an issue with the FC fabric or the adapter. Contact NetApp technical support.
Syslog Message
FC-VI adapter: FCVI driver on port %s received IO error. Status = %s(status code = 0x%x), FCVI opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu.
status_str (STRING): Completion status in string.
status (INTHEX): Completion status code.
qpName (STRING): QP name.
qpIndex (INT): QP number.
fcvi.qlgc.login.timedout
Severity
NOTICE
This message occurs when port login request times out.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Remote port login timedout on port %s. Remote port id = 0x%x, Remote port handle = %d. %s
portid (INTHEX): Remote port identifier.
porthandle (INT): Remote port handle.
fcvi.qlgc.ls.reject
Severity
ERROR
This message occurs when the FCVI firmware rejects a link service.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Link service = %s(code = %d), rejected on port %s. %s
ls (STRING): Link service name.
ls_code (INT): Link service code.
fcvi.qlgc.mbox.cmd.pending
Severity
ERROR
This message occurs when a mailbox command is pending for a long time.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Mailbox command '%s(code = 0x%x)' pending on port %s. %s
cmd (STRING): Mailbox command.
cmd_code (INTHEX): Mailbox command code.
fcvi.qlgc.mbox.cmd.timedout
Severity
ERROR
This message occurs when a mailbox command times out.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Mailbox command '%s(code = 0x%x)' timedout on port %s. %s
fcvi.qlgc.no.iu.buffer
Severity
ERROR
This message occurs when the FCVI firmware identifies no more incoming IU buffers in the free pool.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s doesn't have free IU buffer. %s
fcvi.qlgc.no.recv.buffer
Severity
ERROR
This message occurs when the FCVI firmware identifies no more receive buffers available for the incoming receive frames.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s doesn't have free receive buffer. QP name = %s, QP index = %d, Message ID = 0x%x. %s
msg_id (INTHEX): Message id of the incoming message.
fcvi.qlgc.oodErr
Severity
ERROR
This message occurs when the FC-VI driver receives out of order completions.
Corrective Action
Syslog Message
FC-VI adapter: FCVI driver on port %s receives out of order completions. FCVI opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu.
fcvi.qlgc.PCIErr
Severity
ERROR
This message occurs when the FC-VI adapter firmware encounters a PCI error because it cannot write a frame to host memory.
Corrective Action
(None).
Syslog Message
FC-VI adapter: PCI error while writing a frame to host memory. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
fcvi.qlgc.port.reset
Severity
ERROR
This message occurs when a FCVI port resets.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Resetting the port %s. %s
reason (STRING): Reason for port reset.
fcvi.qlgc.qp.create.err
Severity
ERROR
This message occurs when QP creation fails.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Failed to create QP on port %s. Requested QP index = %d, completion status = %s(status code = %d). %s
fcvi.qlgc.qp.destroy.failed
Severity
ERROR
This message occurs when the QP destroy request failed.
Corrective Action
(None).
Syslog Message
FC-VI adapter: QP destroy failed on port %s. QP index = %d. %s
fcvi.qlgc.qpErr
Severity
ERROR
This message occurs when the FC-VI driver receives a QP error from the Firmware. The FC-VI driver will attempt to retry the connection.
Corrective Action
Syslog Message
FC-VI adapter: FCVI driver on port %s received QP Error. QP name = %s, QP index = 0x%x, VI state = %s(state code = 0x%x), sub-error = %s(error code = 0x%x). Remote node's system id = %llu. This error has occurred %d times. %s
port (STRING): Interconnect Adapter.
qpnum (INTHEX): QP number.
state_str (STRING): QP state.
state (INTHEX): QP state code.
suberror (STRING): Sub-error.
code (INTHEX): Sub-error code.
system_id (LONGINT): Remote node's system ID.
errcnt (INT): Number of times QP async error was encountered.
fcvi.qlgc.rcvd.invalid.iu.buffer
Severity
ERROR
This message occurs when the FC-VI adapter receives invalid information unit buffer.
Corrective Action
Syslog Message
FC-VI adapter: Port %s received invalid IU buffer. Status = %s(status code = 0x%x), FCVI opcode = %s(0x%x), QP name = %s, QP index = %d, buffer handle = %d, Remote node's system id = %llu. %s
bufhdl (INT): Buffer handle.
fcvi.qlgc.receive.error
Severity
ERROR
This message occurs when the FCVI firmware detects an error in the received frame.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Received bad frame on port %s. Mailbox-1 = %d, Mailbox-2 = %d. %s
mbox1 (INT): Content of mailbox-1.
mbox2 (INT): Content of mailbox-2.
fcvi.qlgc.received.disconnect
Severity
NOTICE
This message occurs when FCVI driver receives disconnect request from partner.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Disconnect request received on port %s. QP name = %s, QP index = %d, Remote node's system id = %llu. %s
fcvi.qlgc.received.reject
Severity
NOTICE
This message occurs when FCVI driver receives connection reject from partner.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Connect request rejected on port %s. QP name = %s, QP index = %d, Remote node's system id = %llu. %s
fcvi.qlgc.recvIUErr
Severity
ERROR
This message occurs when the FC-VI adapter receives some error in received information unit.
Corrective Action
Syslog Message
FC-VI adapter: Port %s received IU error. Status = %s(status code = 0x%x), FCVI opcode = %s(0x%x), QP name = %s, QP index = %d, buffer handle = %d, Remote node's system id = %llu.
fcvi.qlgc.regDumped
Severity
NOTICE
This message occurs when the FCVI driver saves a diagnostic dump in a file.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Diagnostic dump for port %s saved to file %s.
filename (STRING): File to which the diagnostic dump was saved.
fcvi.qlgc.RespFrameErr
Severity
ERROR
This message occurs when the adapter firmware sends a response frame with the error bit set.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Firmware sent a response with the error bit set. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
fcvi.qlgc.risc.paused
Severity
ERROR
This message occurs when FCVI RISC is paused.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Port %s detected a RISC pause error. %s
Severity
NOTICE
This message occurs when FCVI driver lost link to partner port.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Link to partner node over port %s is down. Partner port id = 0x%x, partner node's system id = %llu. %s
port_id (INTHEX): Partner port id.
system_id (LONGINT): Partner node's system id.
Severity
NOTICE
This message occurs when FCVI driver gets link to partner port.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Link to partner node over port %s is up. Partner port id = 0x%x, partner node's system id = %llu. %s
fcvi.qlgc.sendIUError
Severity
ERROR
This message occurs when the FC-VI adapter fails to send an information unit.
Corrective Action
No corrective action is required. The driver internally retries. However, if you see this message frequently, there might be an issue with the FC fabric or the adapter. Contact NetApp technical support.
Syslog Message
FC-VI adapter: Port %s sendIU status = %s(status code = 0x%x), FCVI opcode = %s(0x%x), QP name = %s, QP index = %d, Remote node's system id = %llu. %s
status (INTHEX): Completion status code in hex.
opcode (INTHEX): FCVI opcode in hex.
systemID (LONGINT): Remote node's system id.
fcvi.qlgc.sent.disconnect
Severity
NOTICE
This message occurs when FCVI driver sends disconnect request to remote partner.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Disconnect request sent on port %s. QP name = %s, QP index = %d, Remote node's system id = %llu. %s
fcvi.qlgc.soft.reset.failed
Severity
ERROR
Corrective Action
None.
Syslog Message
FC-VI adapter: Soft reset failed at port %s.
fcvi.qlgc.system.error
Severity
ERROR
This message occurs when FCVI driver receives system error from FCVI firmware.
Corrective Action
No corrective action is required. The driver internally resets the adapter. However, if you see this message frequently, there might be an issue with the adapter/firmware. Contact NetApp technical support.
Syslog Message
FC-VI adapter: System Error on port %s. %s
fcvi.qlgc.TimeOutErr
Severity
ERROR
This message occurs when the adapter firmware cannot send a request.
Corrective Action
(None).
Syslog Message
FC-VI adapter: Firmware could not send a request. Port %s, QP name = %s, QP index = %d, exchange ID 0x%x, address offset 0x%x, remote node's system id = %llu. %s
fcvi.qlgc.transfer.error
Severity
ERROR
This message occurs when the FCVI firmware detects a transfer error.
Corrective Action
(None).
Syslog Message
FC-VI adapter: %s transfer error on port %s. Affected queue number = %d. %s
trans_type (STRING): Transfer type.
queue_num (INT): Queue number.
