ONTAP EMS reference
monitor.rtchighpower events
monitor.rtchighpower EMS events occur when the real-time clock (RTC) battery voltage is above normal level.
monitor.rtcHighPower
Severity
ERROR
This message occurs when the real-time clock (RTC) battery voltage is above normal level.
Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the real-time clock battery voltage is still above normal 60 minutes after environmental problems have been corrected, replace it at the next available maintenance window.
Syslog Message
Real-time clock battery voltage is above normal (%s).
reading (STRING): Battery voltage reading (mV).
