monitor.rtchighpower events
monitor.rtcHighPower
- Severity
ERROR
- Description
This message occurs when the real-time clock (RTC) battery voltage is above normal level.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the real-time clock battery voltage is still above normal 60 minutes after environmental problems have been corrected, replace it at the next available maintenance window.
- Syslog Message
Real-time clock battery voltage is above normal (%s).
- Parameters
reading (STRING): Battery voltage reading (mV).
