The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
monitor.rtchighpower events
Creating your file...
Your file is ready
monitor.rtcHighPower
- Severity
ERROR
- Description
This message occurs when the real-time clock (RTC) battery voltage is above normal level.
- Corrective Action
Correct any environmental problems, such as chassis over- temperature. If the real-time clock battery voltage is still above normal 60 minutes after environmental problems have been corrected, replace it at the next available maintenance window.
- Syslog Message
Real-time clock battery voltage is above normal (%s).
- Parameters
reading (STRING): Battery voltage reading (mV).
