ONTAP EMS reference
sis.aggr events
sis.aggr EMS events occur when ONTAP encounters issues associated with Single Instance Storage (SIS) aggregate operations.
sis.aggr.cvs.undo.abort
Severity
NOTICE
This message occurs when undo of cross volume savings on aggregate has to abort due to some error conditions.
Corrective Action
(None).
Syslog Message
Undo of cross volume savings on aggregate %s aborted. Volume %s encountered error: %s
aggr_name (STRING): Aggregate name.
vvol_name (STRING): Flex volume name.
error (STRING): Error code for the abort.
sis.aggr.metadir.create.failed
Severity
ERROR
This message occurs when the creation of SIS metafiles in the aggregate containing the SIS volume fails. Change logging will be turned off on the volume.
Corrective Action
Ensure that space is available in the aggregate containing the volume. Use the 'sis on' command to turn on change logging on the volume, which attempts to re-create SIS metafiles in the aggregate. If enough space is available, start wafliron on the aggregate containing the indicated flexible volume.
Syslog Message
Creation of aggregate metadir failed for SIS volume %s%s. Change logging will be turned off on the volume: %s.
volname (STRING): SIS volume name.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
reason (STRING): Reason for the failure.
