sis.aggr events
Creating your file...
sis.aggr.cvs.undo.abort
- Severity
NOTICE
- Description
This message occurs when undo of cross volume savings on aggregate has to abort due to some error conditions.
- Corrective Action
(None).
- Syslog Message
Undo of cross volume savings on aggregate %s aborted. Volume %s encountered error: %s
- Parameters
aggr_name (STRING): Aggregate name.
vvol_name (STRING): Flex volume name.
error (STRING): Error code for the abort.
sis.aggr.metadir.create.failed
- Severity
ERROR
- Description
This message occurs when the creation of SIS metafiles in the aggregate containing the SIS volume fails. Change logging will be turned off on the volume.
- Corrective Action
Ensure that space is available in the aggregate containing the volume. Use the 'sis on' command to turn on change logging on the volume, which attempts to re-create SIS metafiles in the aggregate. If enough space is available, start wafliron on the aggregate containing the indicated flexible volume.
- Syslog Message
Creation of aggregate metadir failed for SIS volume %s%s. Change logging will be turned off on the volume: %s.
- Parameters
volname (STRING): SIS volume name.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
reason (STRING): Reason for the failure.
