mgmt.cifsshare events
Creating your file...
mgmt.cifsshare.duplicatesid
- Severity
NOTICE
- Description
This message occurs when a network client attempts to set a CIFS share's discretionary access control list (DACL) to a list where any security descriptor (SID) appears in more than one access control entry (ACE). The operation is failed and no changes are made to the share's DACL.
- Corrective Action
(None).
- Syslog Message
Duplicate SID not supported in CIFS share DACL %s
- Parameters
vservername (STRING): Name of the Vserver.
cifssharename (STRING): Name of the CIFS share.
sid (STRING): Textual SID.
mgmt.cifsshare.failure
- Severity
ERROR
- Description
This message occurs when configuration of a CIFS share fails; CIFS access to the share might not be available.
- Corrective Action
Check the reason for the error and take action accordingly.
- Syslog Message
Failed to configure CIFS share. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
cifsservername (STRING): Name of the cifs server.
cifssharename (STRING): Name of the cifs share.
mgmt.cifsshare.success
- Severity
INFORMATIONAL
- Description
This message occurs when a CIFS share is successfully configured after a failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
