nvmeof.onlyoneport events
Creating your file...
Your file is ready
nvmeof.onlyoneport.clear
- Severity
NOTICE
- Description
This message occurs when there is no longer only one port cabled from a node to a shelf.
- Corrective Action
(None).
- Syslog Message
There is no longer only one port cabled from node %s to shelf with SN %s.
- Parameters
node_name (STRING): Host name connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.onlyoneport.error
- Severity
ERROR
- Description
This message occurs when host port is incorrectly cabled to a shelf.
- Corrective Action
The host port is incorrectly cabled to shelf. two ports must be connected to ensure redundancy.
- Syslog Message
There is only one port cabled from node %s to Shelf with SN %s.
- Parameters
