vol.clone events
vol.clone EMS events occur when the clone split of a volume clone takes the optimized path which uses an Azure copy blob operation to copy objects from the parent volume to the clone.
vol.clone.split.optimized
- Severity
NOTICE
- Description
This message occurs when the clone split of a volume clone takes the optimized path which uses an Azure copy blob operation to copy objects from the parent volume to the clone.
- Corrective Action
(None).
- Syslog Message
Clone split of volume "%s" hosted on FabricPool "%s" takes the optimized path using Azure copy blob operation.
- Parameters
volume_name (STRING): Volume clone.
aggregate_name (STRING): Aggregate which hosts the volume clone.
