monitor.shutdown events
Creating your file...
monitor.shutdown.brokenDisk
- Severity
EMERGENCY
- Description
This message occurs when an automatic shutdown sequence is initiated due to a degraded RAID group that cannot be reconstructed because there are insufficient appropriate spare disks. The timeout period is specified by the "raid.timeout" option, which must be set by user to a nonzero value in order for the system to shutdown on expiry of the timeout period. If the option is not set or is set to zero, then system will not shut down due to a degraded RAID group.
- Corrective Action
To recover from the shutdown, boot the system. Ensure that there are sufficient spare disks of the appropriate type so that the degraded RAID group can be reconstructed.
- Syslog Message
%s in RAID group "%s" %s broken. Halting system now.
- Parameters
type (STRING): Type of disk.
rgname (STRING): RAID group name.
verb (STRING): Description of the broken state.
monitor.shutdown.brokenDisk.pending
- Severity
NOTICE
- Description
This message occurs when an automatic shutdown sequence has been postponed due to RAID reconstruction.
- Corrective Action
(None).
- Syslog Message
%s in RAID group "%s" %s broken. Halting system in %d hour%s.
- Parameters
countdown (INT): Number of hours remaining to shutdown.
plural (STRING): Plural character.
monitor.shutdown.cancel
- Severity
NOTICE
- Description
This message occurs when an automatic shutdown sequence is canceled.
- Corrective Action
(None).
- Syslog Message
Automatic shutdown sequence canceled.
- Parameters
(None).
monitor.shutdown.cancel.brokenDisk
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
%s in RAID group "%s" %s broken. Halt delayed until %s finishes.
- Parameters
reason (STRING): Reason that the shutdown was postponed. Possible reasons are "RAID reconstruction" and "parity recomputation".
monitor.shutdown.cancel.nvramLowBatteries
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
NVRAM batteries are dangerously low. Halt delayed until %s finishes.
- Parameters
reason (STRING): Reason that the shutdown was postponed. Possible reasons are "RAID reconstruct" and "parity recomputation".
monitor.shutdown.cancel.nvramLowBattery
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
NVRAM battery is dangerously low. Halt delayed until %s finishes.
- Parameters
monitor.shutdown.chassisOverTemp
- Severity
EMERGENCY
- Description
This message occurs when the chassis temperature is too hot. This is sent just before shutdown.
- Corrective Action
Ensure that sufficient cooling air is being supplied to the chassis and that the air inlets and outlets of the unit are not blocked.
- Syslog Message
Chassis temperature is too hot: %s
- Parameters
describe_toohot (STRING): Description of the condition.
monitor.shutdown.chassisUnderTemp
- Severity
ERROR
- Description
This message occurs when the system is shutting down because chassis temperature is too cold.
- Corrective Action
The appliance is in an environment that is too cold. Find a way to warm the environment around the appliance.
- Syslog Message
Chassis temperature is too cold: %s
- Parameters
describe_toocold (STRING): Description of the condition.
monitor.shutdown.emergency
- Severity
EMERGENCY
- Description
This message occurs when ONTAP® initiates an emergency shutdown.
- Corrective Action
Correct the condition noted in the reason field.
- Syslog Message
Emergency shutdown: %s
- Parameters
reason (STRING): Reason for the shutdown.
monitor.shutdown.ioexpansionOverTemp
- Severity
EMERGENCY
- Description
This message occurs when the I/O expansion module is too hot. This message is sent just before shutdown.
- Corrective Action
The system environment is too hot; cool the environment.
- Syslog Message
I/O expansion module is too hot: %s
- Parameters
describe_toohot (STRING): Reading and state of the temperature sensors on the I/O expansion module.
monitor.shutdown.ioexpansionUnderTemp
- Severity
EMERGENCY
- Description
This message occurs when the I/O expansion module is too cold. This message is sent just before shutdown.
- Corrective Action
The system environment is too cold; warm the environment.
- Syslog Message
I/O expansion module is too cold: %s
- Parameters
describe_toocold (STRING): Reading and state of the temperature sensors on the I/O expansion module.
monitor.shutdown.nvramLowBatteries
- Severity
EMERGENCY
- Description
This message occurs when the NVRAM power in a controller with multiple NVRAM batteries is dangerously low, and ONTAP® initiates a shutdown to protect user data.
- Corrective Action
Replace the controller NVRAM batteries.
- Syslog Message
Emergency shutdown: NVRAM batteries dangerously low in degraded mode. Replace the batteries immediately!
- Parameters
(None).
monitor.shutdown.nvramLowBatteries.pending
- Severity
ALERT
- Description
This message occurs when an automatic shutdown sequence is pending because of low NVRAM batteries voltage.
- Corrective Action
- Syslog Message
NVRAM batteries are dangerously low. Halting system in %d hour%s. Replace the batteries immediately!
- Parameters
countdown (INT): Hours remaining until shutdown.
plural (STRING): Grammatical number.
monitor.shutdown.nvramLowBattery
- Severity
EMERGENCY
- Description
This message occurs when the controller NVRAM voltage is dangerously low, and ONTAP® initiates a shutdown to protect user data.
- Corrective Action
Replace the controller NVRAM battery.
- Syslog Message
Emergency shutdown: NVRAM battery dangerously low in degraded mode. Replace the battery immediately!
- Parameters
(None).
monitor.shutdown.nvramLowBattery.pending
- Severity
ALERT
- Description
This message occurs when an automatic shutdown sequence is pending because of low NVRAM battery voltage.
- Corrective Action
- Syslog Message
NVRAM battery is dangerously low. Halting system in %d hour%s. Replace the battery immediately!
- Parameters
