sms.failed events
sms.failed EMS events occur when a SnapMirror® Sync relationship cannot be established due to precheck failures.
sms.failed.precheck
- Severity
ERROR
- Description
This message occurs when a SnapMirror® Sync relationship cannot be established due to precheck failures.
- Corrective Action
Monitor the status of the SnapMirror Sync relationship by using the "snapmirror show" command. Retry the SnapMirror Sync operation after resolving the issue that caused the precheck failure.
- Syslog Message
SnapMirror Sync operation failed for source volume "%s" and destination volume "%s" with relationship UUID "%s" due to the following reason: "%s".
- Parameters
srcpath (STRING): Path name of the source volume of the SnapMirror relationship.
dstpath (STRING): Path name of the destination volume of the SnapMirror relationship.
relationship_id (STRING): Relationship UUID.
error_msg (STRING): Reason for the failure.
