ONTAP EMS reference
sms.failed events
sms.failed EMS events occur when a SnapMirror® Sync relationship cannot be established due to precheck failures.
sms.failed.precheck
Severity
ERROR
This message occurs when a SnapMirror® Sync relationship cannot be established due to precheck failures.
Corrective Action
Monitor the status of the SnapMirror Sync relationship by using the "snapmirror show" command. Retry the SnapMirror Sync operation after resolving the issue that caused the precheck failure.
Syslog Message
SnapMirror Sync operation failed for source volume "%s" and destination volume "%s" with relationship UUID "%s" due to the following reason: "%s".
srcpath (STRING): Path name of the source volume of the SnapMirror relationship.
dstpath (STRING): Path name of the destination volume of the SnapMirror relationship.
relationship_id (STRING): Relationship UUID.
error_msg (STRING): Reason for the failure.
