The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
wafl.volref events
Creating your file...
Your file is ready
wafl.volref.subsystem.string
- Severity
ERROR
- Description
This message occurs when wafliron is started on aggregate containing volumes, which are in-use by other subsystems.
- Corrective Action
Stop the subsystem which is using this volume/aggregate So that wafliron can be run.
- Syslog Message
wafliron: %s %s is being used by '%s'
- Parameters
type (STRING): Type of object (volume or aggregate).
vol (STRING): Name of the volume or aggregate.
volref (STRING): volume reference string of the subsystem using this volume/aggregate.
