wafl.volref events
Creating your file...
Your file is ready
wafl.volref.subsystem.string
- Severity
ERROR
- Description
This message occurs when wafliron is started on aggregate containing volumes, which are in-use by other subsystems.
- Corrective Action
Stop the subsystem which is using this volume/aggregate So that wafliron can be run.
- Syslog Message
wafliron: %s %s is being used by '%s'
- Parameters
type (STRING): Type of object (volume or aggregate).
vol (STRING): Name of the volume or aggregate.
volref (STRING): volume reference string of the subsystem using this volume/aggregate.
