ONTAP EMS reference
master.releasing events
master.releasing EMS events occur when a node is demoted from being the cluster master.
master.releasing.cm
Severity
NOTICE
This message occurs when the node is demoted from being the cluster master.
Corrective Action
(None).
Syslog Message
Service ID %u on node ID %u (UUID: %s) releases control as the cluster master.
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
