master.releasing events
Creating your file...
Your file is ready
master.releasing.cm
- Severity
NOTICE
- Description
This message occurs when the node is demoted from being the cluster master.
- Corrective Action
(None).
- Syslog Message
Service ID %u on node ID %u (UUID: %s) releases control as the cluster master.
- Parameters
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
