nblade.nocsmsession events
Creating your file...
Your file is ready
Nblade.noCsmSession
- Severity
NOTICE
- Description
This message occurs when the local node could not acquire a Connection Session Manager (CSM) session. CSM sessions are used to communicate file operations between nodes in the cluster. This might be a transient condition. If this condition persists, volumes on the destination node remain unavailable from this node. The destination node can be either local or remote.
- Corrective Action
Check IP connectivity over the cluster interfaces between the two nodes. If further assistance is needed, contact NetApp technical support.
- Syslog Message
(None).
- Parameters
bladeId (STRING): UUID of the node that could not be reached.
