nblade.nocsmsession events
Nblade.noCsmSession
Severity
NOTICE
This message occurs when the local node could not acquire a Connection Session Manager (CSM) session. CSM sessions are used to communicate file operations between nodes in the cluster. This might be a transient condition. If this condition persists, volumes on the destination node remain unavailable from this node. The destination node can be either local or remote.
Corrective Action
Check IP connectivity over the cluster interfaces between the two nodes. If further assistance is needed, contact NetApp technical support.
Syslog Message
(None).
bladeId (STRING): UUID of the node that could not be reached.
