cf.sysid events
cf.sysid.sent
- Severity
INFORMATIONAL
- Description
This message occurs when a node sends its system ID and its HA partner's system ID successfully across the HA interconnect.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
sysid (LONGINT): Value of the local system ID that was sent successfully .
host (STRING): This parameter is obsolete from Data ONTAP®8.3 and later because the parter's systemID is also sent in the message.
partner_sysid (LONGINT): Value of the partner system ID that was sent successfully.
