ONTAP EMS reference
cf.sysid events
cf.sysid EMS events occur when a node sends its system ID and its HA partner's system ID successfully across the HA interconnect.
cf.sysid.sent
Severity
INFORMATIONAL
This message occurs when a node sends its system ID and its HA partner's system ID successfully across the HA interconnect.
Corrective Action
(None).
Syslog Message
(None).
sysid (LONGINT): Value of the local system ID that was sent successfully .
host (STRING): This parameter is obsolete from Data ONTAP®8.3 and later because the parter's systemID is also sent in the message.
partner_sysid (LONGINT): Value of the partner system ID that was sent successfully.
