      config.sameslot events
config.sameSlot
- Severity
ERROR
 - Description
This message occurs when a SAS disk is multipathed to host adapters in the same controller slot. The second disk interface should be attached to a host adapter in a different slot.
 - Corrective Action
Move one of the connections attaching the disk shelf to a host adapter in a different slot.
 - Syslog Message
Disk %s and other disks attached to the same port are dual-attached to adapters in the same slot . For improved availability you should dual-attach them to adapters in separate slots.
 - Parameters
disk (STRING): Name of the disk.
