vifmgr.migratelifs events
vifmgr.migrateLifs.nlbdDown
Severity
ERROR
This message occurs when the network load balancing listener is not responding to probes over a node management LIF, and cluster-scoped LIFs with the same current port have been migrated elsewhere.
Corrective Action
Use the "network interface show" command to verify that the node managment LIF in question is operational. If the LIF is operational, contact NetApp technical support for specific instructions.
Syslog Message
The network load balancing listener is not responding via LIF "%s" on Vserver "%s" with current port "%s". As a result, the load balancing LIFs have been migrated elsewhere.
lif (STRING): LIF name.
vserver_name (STRING): Vserver name.
port (STRING): Network port name
vifmgr.migrateLifs.nlbdUp
Severity
NOTICE
This message occurs when the network load balancing listener starts responding to probes over a node management LIF. The network port where the node management LIF is located is now available for use by load-balanced LIFs.
Corrective Action
(None).
Syslog Message
The network load balancing listener has started responding via LIF "%s" on Vserver "%s" with current port "%s".
port (STRING): Network port name.
