diskown.shlf events
Creating your file...
diskown.Shlf.assignStatus
- Severity
NOTICE
- Description
This message occurs when shelf granular-based drive assignment is enabled or disabled. This is currently applicable for an MetroCluster(tm) IP configurations.
- Corrective Action
(None).
- Syslog Message
Shelf-based automatic drive assignment for shelf "%d" is "%s".
- Parameters
shelf_id (INT): Shelf identifier.
state (STRING): Shelf-based automatic drive assignment state.
diskown.Shlf.MultiOwners
- Severity
ERROR
- Description
This message occurs when the system cannot automatically assign disks because some of the disks are assigned to multiple nodes in a conflicting manner. Until the disk assignments are corrected, the specified shelf will be excluded during auto assignment, and unowned disks on the shelf will be skipped.
- Corrective Action
1) Find all of the disks belonging to the specified shelf by using the "storage disk show -fields owner,shelf" command. 2) Ensure that the disks on the shelf are assigned to a single system by manually assigning disks in the shelf to a single owner.
- Syslog Message
The system cannot automatically assign disks because the disks in shelf %d are assigned to multiple nodes in a conflicting manner.
- Parameters
