ONTAP EMS reference
diskown.shlf events
diskown.shlf EMS events occur when ONTAP encounters issues associated with shelf-based drive assignment.
diskown.Shlf.assignStatus
Severity
NOTICE
This message occurs when shelf granular-based drive assignment is enabled or disabled. This is currently applicable for an MetroCluster(tm) IP configurations.
Corrective Action
(None).
Syslog Message
Shelf-based automatic drive assignment for shelf "%d" is "%s".
shelf_id (INT): Shelf identifier.
state (STRING): Shelf-based automatic drive assignment state.
diskown.Shlf.MultiOwners
Severity
ERROR
This message occurs when the system cannot automatically assign disks because some of the disks are assigned to multiple nodes in a conflicting manner. Until the disk assignments are corrected, the specified shelf will be excluded during auto assignment, and unowned disks on the shelf will be skipped.
Corrective Action
1) Find all of the disks belonging to the specified shelf by using the "storage disk show -fields owner,shelf" command. 2) Ensure that the disks on the shelf are assigned to a single system by manually assigning disks in the shelf to a single owner.
Syslog Message
The system cannot automatically assign disks because the disks in shelf %d are assigned to multiple nodes in a conflicting manner.
