connectx.ibretimerskipprogrm events
connectx.IbRetimerSkipProgrm
- Severity
INFORMATIONAL
- Description
This message occurs when InfiniBand retimer programming is skipped after the system detects that a cable is plugged in, because there was no change in the cable's type and length.
- Corrective Action
(None).
- Syslog Message
InfiniBand retimer programming was skipped on port %s for %s cable.
- Parameters
port_str (STRING): InfiniBand port in which the cable is plugged.
cable_type (STRING): InfiniBand cable type.
