The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
connectx.ibretimerskipprogrm events
Creating your file...
Your file is ready
connectx.IbRetimerSkipProgrm
- Severity
INFORMATIONAL
- Description
This message occurs when InfiniBand retimer programming is skipped after the system detects that a cable is plugged in, because there was no change in the cable's type and length.
- Corrective Action
(None).
- Syslog Message
InfiniBand retimer programming was skipped on port %s for %s cable.
- Parameters
port_str (STRING): InfiniBand port in which the cable is plugged.
cable_type (STRING): InfiniBand cable type.
