ONTAP EMS reference
connectx.ibretimerskipprogrm events
connectx.ibretimerskipprogrm EMS events occur when InfiniBand retimer programming is skipped after the system detects that a cable is plugged in, because there was no change in the cable's type and length.
connectx.IbRetimerSkipProgrm
Severity
INFORMATIONAL
This message occurs when InfiniBand retimer programming is skipped after the system detects that a cable is plugged in, because there was no change in the cable's type and length.
Corrective Action
(None).
Syslog Message
InfiniBand retimer programming was skipped on port %s for %s cable.
port_str (STRING): InfiniBand port in which the cable is plugged.
cable_type (STRING): InfiniBand cable type.
