arl.precmt events
arl.precmt.lmgr.resync.abrt
- Severity
NOTICE
- Description
This message occurs during aggregate relocation, when automatic lock resynchronization with the node’s high-availability (HA) partner for files on this aggregate was aborted.
- Corrective Action
(None).
- Syslog Message
Automatic lock resynchronization was aborted for aggregate %s on forced relocation.
- Parameters
aggr (STRING): Name of the aggregate for which resynchronization was aborted.
arl.precmt.lmgr.resyncing
- Severity
ERROR
- Description
This message occurs during aggregate relocation, when automatic lock resynchronization with the node’s high-availability (HA) partner is in progress for files on this aggregate.
- Corrective Action
Retry the relocation after verifying that lock synchronization is complete by using the 'debug locks auto-resync-status -aggregate <aggregate>' diagnostic privilege command. If lock state disruption for all CA locks on the aggregate is acceptable, retry the aggregate relocation with the '-override-vetoes true' option.
- Syslog Message
Could not relocate aggregate %s because automatic lock resynchronization was in progress.
- Parameters
aggr (STRING): Name of the aggregate with locks not yet in sync.
arl.precmt.lmgr.sync.failed
- Severity
ERROR
- Description
This message occurs when relocation of an aggregate has started but mirrored lock state cannot be created locally for the relocating aggregate. The relocate operation is aborted.
- Corrective Action
Take the appropriate action based on the reason supplied in the logged message: - 'Timed Out': Retry the aggregate relocation with the '-override-destination-checks' option. Overriding the check might result in a longer administrative outage period during which no administrative operations can be performed for volumes on this aggregate. - 'Fatal Error': Contact NetApp technical support.
- Syslog Message
Could not relocate the aggregate %s because creating locally mirrored lock state failed.
- Parameters
aggr (STRING): Name of the aggregate being relocated.
reason (STRING): Reason the local mirrored lock state creation failed.
arl.precmt.lmgr.sync.forced
- Severity
NOTICE
- Description
This message occurs during aggregate relocation, when local mirrored lock state creation is allowed to proceed without any time restrictions. This might result in a longer administrative outage period during which no administrative operations can be performed for volumes on this aggregate.
- Corrective Action
(None).
- Syslog Message
Local mirrored lock state creation for relocating aggregate %s is proceeding without time restrictions.
- Parameters
arl.precmt.repl
- Severity
NOTICE
- Description
This message occurs when all replication transfers are aborted because of aggregate relocation.
- Corrective Action
(None).
- Syslog Message
Replication transfers aborted due to aggregate relocation.
- Parameters
(None).
arl.precmt.vdom.lowMem
- Severity
ERROR
- Description
This message occurs when an aggregate relocation fails due to the unavailability of Data ONTAP® memory on the source node.
- Corrective Action
Free some memory and retry the aggregate relocation.
- Syslog Message
Relocation of aggregate %s failed due to unavailability of Data ONTAP® memory on the source node.
- Parameters
aggr (STRING): Name of the aggregate that was not relocated.
arl.precmt.wafl.volconversion
- Severity
ERROR
- Description
This message occurs when an active volume conversion is running on one or more volumes on the source aggregate. Pre-commit is aborted.
- Corrective Action
When volume conversion is complete, re-run the command 'storage aggregate relocation start'.
- Syslog Message
Aggregate relocation/takeover is blocked as Volume Conversion is in progress on one of the volumes on aggregate %s.
- Parameters
aggregate_name (STRING): The name of the aggregate containing the volume on which conversion is in progress.
