ONTAP EMS reference
arl.precmt events
arl.precmt EMS events occur when ONTAP encounters issues associated with lock resynchronization and mirrored lock state creation during the aggregate relocation pre-commit phase.
arl.precmt.lmgr.resync.abrt
Severity
NOTICE
This message occurs during aggregate relocation, when automatic lock resynchronization with the node's high-availability (HA) partner for files on this aggregate was aborted.
Corrective Action
(None).
Syslog Message
Automatic lock resynchronization was aborted for aggregate %s on forced relocation.
aggr (STRING): Name of the aggregate for which resynchronization was aborted.
arl.precmt.lmgr.resyncing
Severity
ERROR
This message occurs during aggregate relocation, when automatic lock resynchronization with the node's high-availability (HA) partner is in progress for files on this aggregate.
Corrective Action
Retry the relocation after verifying that lock synchronization is complete by using the 'debug locks auto-resync-status -aggregate <aggregate>' diagnostic privilege command. If lock state disruption for all CA locks on the aggregate is acceptable, retry the aggregate relocation with the '-override-vetoes true' option.
Syslog Message
Could not relocate aggregate %s because automatic lock resynchronization was in progress.
aggr (STRING): Name of the aggregate with locks not yet in sync.
arl.precmt.lmgr.sync.failed
Severity
ERROR
This message occurs when relocation of an aggregate has started but mirrored lock state cannot be created locally for the relocating aggregate. The relocate operation is aborted.
Corrective Action
Take the appropriate action based on the reason supplied in the logged message: - 'Timed Out': Retry the aggregate relocation with the '-override-destination-checks' option. Overriding the check might result in a longer administrative outage period during which no administrative operations can be performed for volumes on this aggregate. - 'Fatal Error': Contact NetApp technical support.
Syslog Message
Could not relocate the aggregate %s because creating locally mirrored lock state failed.
aggr (STRING): Name of the aggregate being relocated.
reason (STRING): Reason the local mirrored lock state creation failed.
arl.precmt.lmgr.sync.forced
Severity
NOTICE
This message occurs during aggregate relocation, when local mirrored lock state creation is allowed to proceed without any time restrictions. This might result in a longer administrative outage period during which no administrative operations can be performed for volumes on this aggregate.
Corrective Action
(None).
Syslog Message
Local mirrored lock state creation for relocating aggregate %s is proceeding without time restrictions.
arl.precmt.repl
Severity
NOTICE
This message occurs when all replication transfers are aborted because of aggregate relocation.
Corrective Action
(None).
Syslog Message
Replication transfers aborted due to aggregate relocation.
(None).
arl.precmt.vdom.lowMem
Severity
ERROR
This message occurs when an aggregate relocation fails due to the unavailability of Data ONTAP® memory on the source node.
Corrective Action
Free some memory and retry the aggregate relocation.
Syslog Message
Relocation of aggregate %s failed due to unavailability of Data ONTAP® memory on the source node.
aggr (STRING): Name of the aggregate that was not relocated.
arl.precmt.wafl.volconversion
Severity
ERROR
This message occurs when an active volume conversion is running on one or more volumes on the source aggregate. Pre-commit is aborted.
Corrective Action
When volume conversion is complete, re-run the command 'storage aggregate relocation start'.
Syslog Message
Aggregate relocation/takeover is blocked as Volume Conversion is in progress on one of the volumes on aggregate %s.
aggregate_name (STRING): The name of the aggregate containing the volume on which conversion is in progress.
