disk.sanit events
disk.sanit EMS events occur when ONTAP encounters issues associated with disk sanitization operations.
disk.sanit.complete
- Severity
INFORMATIONAL
- Description
This message occurs when disk sanitization has been completed.
- Corrective Action
(None).
- Syslog Message
Disk %s [S/N %s] has completed sanitization.
- Parameters
diskName (STRING): Name of the device.
serialno (STRING): Serial number of the device.
disk.sanit.error
- Severity
ERROR
- Description
This message occurs when a disk returns an error during sanitization.
- Corrective Action
Verify that the drive is capable of sanitization. See the ONTAP® Physical Storage Management Guide https://library.netapp.com/ecmdocs/ECMP12458210/html/GUID-1DC1DEC2-AAB3-483E-805D-82E722023AA6.html for more information.
- Syslog Message
Disk %s has received an error %d (0%xh/0%xh/0%xh/0%xh) during sanitization.
- Parameters
diskName (STRING): Name of the disk.
scsi_error (INT): SCSI error code.
sense_key (INT): Actual sense key.
sense_code (INT): Actual sense code.
qualifier (INT): Actual sense code qualifier.
fru_failed (INT): Actual FRU code.
disk.sanit.formatComplete
- Severity
INFORMATIONAL
- Description
This message occurs when the disk sanitization format phase is complete.
- Corrective Action
(None).
- Syslog Message
Disk sanitization format complete for disk %s [S/N %s], begin pattern writes.
- Parameters
disk.sanit.formatError
- Severity
ERROR
- Description
This message occurs when disk sanitization formatting fails.
- Corrective Action
(None).
- Syslog Message
Disk %s has received an error %d (0%xh/0%xh/0%xh) during the formatting of the drive. Format will be retried within fifteen minutes.
- Parameters
status (INT): Error code.
sense_key (INTHEX): Actual sense key.
sense_code (INTHEX): Actual sense code.
qualifier (INTHEX): Actual sense code qualifier.
disk.sanit.formatFailed
- Severity
ERROR
- Description
This message occurs when disk sanitization reformatting has been retried unsuccessfully the maximum number of times.
- Corrective Action
Disk sanitization reformatting attempts have been unsuccessful. To make the disk usable, it must be reformatted. You can do this in maintenance mode with the SCSI "format" command.
- Syslog Message
Disk sanitization reformat has failed for disk %s.
- Parameters
disk.sanit.patternDone
- Severity
INFORMATIONAL
- Description
This message occurs when disk sanitization has completed a cycle of a pattern write.
- Corrective Action
(None).
- Syslog Message
Disk %s [S/N %s] cycle %d pattern write of 0x%02x completed in %02d:%02d:%02d.
- Parameters
cycle (INT): Sanitization cycle.
pattern (INT): Pattern byte.
hours (INT): Time in hours.
minutes (INT): Time in minutes.
seconds (INT): Time in seconds.
disk.sanit.randomPatternDone
- Severity
INFORMATIONAL
- Description
This message occurs when disk sanitization has completed a cycle of random data write.
- Corrective Action
(None).
- Syslog Message
Disk %s [S/N %s] cycle %d pattern write of random data completed in %02d:%02d:%02d.
- Parameters
disk.sanit.reformatComplete
- Severity
INFORMATIONAL
- Description
This message occurs when disk sanitization reformatting is complete.
- Corrective Action
(None).
- Syslog Message
Disk %s has been successfully reformatted. To sanitize disk, restart the disk sanitize command. To bypass format, use -s option.
- Parameters
disk.sanit.sanitComplete
- Severity
INFORMATIONAL
- Description
This message occurs when the SCSI sanitize command phase of a 'disk sanitize' command is complete, and the data pattern write phase begins.
- Corrective Action
(None).
- Syslog Message
Sanitization phase of the 'disk sanitize' command was completed for disk %s [S/N %s]. Pattern writes have begun.
- Parameters
