ONTAP EMS reference
disk.sanit events
disk.sanit.complete
Severity
INFORMATIONAL
This message occurs when disk sanitization has been completed.
Corrective Action
(None).
Syslog Message
Disk %s [S/N %s] has completed sanitization.
diskName (STRING): Name of the device.
serialno (STRING): Serial number of the device.
disk.sanit.error
Severity
ERROR
This message occurs when a disk returns an error during sanitization.
Corrective Action
Verify that the drive is capable of sanitization and check the knowledgebase of the support vendor website for the error codes.
Syslog Message
Disk %s has received an error %d (0%xh/0%xh/0%xh/0%xh) during sanitization.
diskName (STRING): Name of the disk.
scsi_error (INT): SCSI error code.
sense_key (INT): Actual sense key.
sense_code (INT): Actual sense code.
qualifier (INT): Actual sense code qualifier.
fru_failed (INT): Actual FRU code.
disk.sanit.formatComplete
Severity
INFORMATIONAL
This message occurs when the disk sanitization format phase is complete.
Corrective Action
(None).
Syslog Message
Disk sanitization format complete for disk %s [S/N %s], begin pattern writes.
disk.sanit.formatError
Severity
ERROR
This message occurs when disk sanitization formatting fails.
Corrective Action
(None).
Syslog Message
Disk %s has received an error %d (0%xh/0%xh/0%xh) during the formatting of the drive. Format will be retried within fifteen minutes.
status (INT): Error code.
sense_key (INTHEX): Actual sense key.
sense_code (INTHEX): Actual sense code.
qualifier (INTHEX): Actual sense code qualifier.
disk.sanit.formatFailed
Severity
ERROR
This message occurs when disk sanitization reformatting has been retried unsuccessfully the maximum number of times.
Corrective Action
Disk sanitization reformatting attempts have been unsuccessful. To make the disk usable, it must be reformatted. You can do this in maintenance mode with the SCSI "format" command.
Syslog Message
Disk sanitization reformat has failed for disk %s.
disk.sanit.patternDone
Severity
INFORMATIONAL
This message occurs when disk sanitization has completed a cycle of a pattern write.
Corrective Action
(None).
Syslog Message
Disk %s [S/N %s] cycle %d pattern write of 0x%02x completed in %02d:%02d:%02d.
cycle (INT): Sanitization cycle.
pattern (INT): Pattern byte.
hours (INT): Time in hours.
minutes (INT): Time in minutes.
seconds (INT): Time in seconds.
disk.sanit.randomPatternDone
Severity
INFORMATIONAL
This message occurs when disk sanitization has completed a cycle of random data write.
Corrective Action
(None).
Syslog Message
Disk %s [S/N %s] cycle %d pattern write of random data completed in %02d:%02d:%02d.
disk.sanit.reformatComplete
Severity
INFORMATIONAL
This message occurs when disk sanitization reformatting is complete.
Corrective Action
(None).
Syslog Message
Disk %s has been successfully reformatted. To sanitize disk, restart the disk sanitize command. To bypass format, use -s option.
disk.sanit.sanitComplete
Severity
INFORMATIONAL
This message occurs when the SCSI sanitize command phase of a 'disk sanitize' command is complete, and the data pattern write phase begins.
Corrective Action
(None).
Syslog Message
Sanitization phase of the 'disk sanitize' command was completed for disk %s [S/N %s]. Pattern writes have begun.
