ONTAP EMS reference
pha.disk events
pha.disk EMS events occur when ONTAP encounters issues associated with backing disk types for existing disks.
pha.disk.type.changed
Severity
ERROR
This message occurs when the backing disk type for an existing disk was changed from the cloud API.
Corrective Action
Check whether the disk type of the failed disk was changed. Change the backing disk type to the original value.
Syslog Message
Backing disk type changed for Disk: %s, Volume: %s. Error: %s.
d_name (STRING): Disk name
d_id (STRING): Disk ID
errmsg (STRING): Indicating the stage at which the disk lookup failed.
pha.disk.type.lookup.failed
Severity
ERROR
This message occurs when the backing disk type lookup fails.
Corrective Action
Check that the disk type of the failed disk is supported. Remove the affected disk.
Syslog Message
Failed to recognize backing disk type for Disk: %s, Volume: %s. Error: %s.
d_name (STRING): Disk name.
