pha.disk events
Creating your file...
Your file is ready
pha.disk.type.changed
- Severity
ERROR
- Description
This message occurs when the backing disk type for an existing disk was changed from the cloud API.
- Corrective Action
Check whether the disk type of the failed disk was changed. Change the backing disk type to the original value.
- Syslog Message
Backing disk type changed for Disk: %s, Volume: %s. Error: %s.
- Parameters
d_name (STRING): Disk name
d_id (STRING): Disk ID
errmsg (STRING): Indicating the stage at which the disk lookup failed.
pha.disk.type.lookup.failed
- Severity
ERROR
- Description
This message occurs when the backing disk type lookup fails.
- Corrective Action
Check that the disk type of the failed disk is supported. Remove the affected disk.
- Syslog Message
Failed to recognize backing disk type for Disk: %s, Volume: %s. Error: %s.
- Parameters
d_name (STRING): Disk name.
