rpc.xprt events
rpc.xprt EMS events occur when ONTAP encounters issues associated with side band Remote Procedure Call (RPC) connection limits.
rpc.xprt.limit
- Deprecated
Deprecated as of version 9.2 where this RPC mechanism was withdrawn.
- Severity
ERROR
- Description
This message occurs when the number of active connections to a side band Remote Procedure Call (RPC) reaches the limit. This limit is not configurable.
- Corrective Action
To check for stale client connections, use the output from the CLI "netstat" command.
- Syslog Message
Active TCP connections to side band RPC service with program number %u has reached a limit of %d connections.
- Parameters
prog (INT): TCP program number of RPC service to which the connection request arrived.
max_conn (INT): Maximum number of active connections to RPC service.
rpc.xprt.vfiler.limit
- Deprecated
- Severity
ERROR
- Description
This message occurs when the number of active connections to side band Remote Procedure Call (RPC) services of a vFiler unit reaches the limit. This limit is not configurable.
- Corrective Action
- Syslog Message
Active TCP connections to side band RPC services of vFiler %s has reached a limit of %d connections.
- Parameters
vfiler (STRING): Name of the vFiler unit to which the connection request arrived.
vf_max_conn (INT): Maximum number of active connections to sideband RPC services of this vFiler unit.
