ONTAP EMS reference
rpc.xprt events
rpc.xprt.limit
Deprecated
Deprecated as of version 9.2 where this RPC mechanism was withdrawn.
Severity
ERROR
This message occurs when the number of active connections to a side band Remote Procedure Call (RPC) reaches the limit. This limit is not configurable.
Corrective Action
To check for stale client connections, use the output from the CLI "netstat" command.
Syslog Message
Active TCP connections to side band RPC service with program number %u has reached a limit of %d connections.
prog (INT): TCP program number of RPC service to which the connection request arrived.
max_conn (INT): Maximum number of active connections to RPC service.
rpc.xprt.vfiler.limit
Deprecated
Severity
ERROR
This message occurs when the number of active connections to side band Remote Procedure Call (RPC) services of a vFiler unit reaches the limit. This limit is not configurable.
Corrective Action
Syslog Message
Active TCP connections to side band RPC services of vFiler %s has reached a limit of %d connections.
vfiler (STRING): Name of the vFiler unit to which the connection request arrived.
vf_max_conn (INT): Maximum number of active connections to sideband RPC services of this vFiler unit.
