The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fmmb.destroy events
Creating your file...
Your file is ready
fmmb.destroy.mbx
- Severity
INFORMATIONAL
- Description
This event is issued when the high-availability (HA) Mailbox contents are cleared, typically by the 'mailbox destroy' command.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
disk_name (STRING): Disk name on which the mailbox was cleared.
fmmb.destroy.mbx.fail
- Severity
NOTICE
- Description
This event is issued when an attempt is made to destroy the mailbox contents on the disk and this fails. Data ONTAP to a 7.0 or later version.
- Corrective Action
(None).
- Syslog Message
Failed to clear mailbox on disk:%s, error:%s.
- Parameters
disk_name (STRING): disk name on which we are trying to clear the mailbox.
error (STRING): The reason why mailbox clear failed.
