ONTAP EMS reference
smc.cg events
smc.cg EMS events occur when a FlexGroup® snapshot rename fails and the revert to the original snapshot name also fails.
smc.cg.snap.ren.revert.fail
Severity
ERROR
This message occurs when a FlexGroup® Snapshot copy rename fails and the revert to the original Snapshot copy name also fails.
Corrective Action
Manually rename the Snapshot copy by issuing the "snapshot rename" command.
Syslog Message
Unable to revert Snapshot copy name from the new name, "%s" to oldname "%s" in volume "%s".
newsnapname (STRING): New Snapshot copy name.
origsnapname (STRING): Original Snapshot copy name.
dstpath (STRING): Path name of the destination volume to which the Snapshot copy rename was issued.
error (INT): Error code of the failure.
