The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ktls.failed events
Creating your file...
Your file is ready
ktls.failed
- Severity
NOTICE
- Description
This message occurs when several successive Transport Layer Security (TLS) connections with a remote system have failed.
- Corrective Action
Corrective actions will necessarily depend on what condition is being reported.
- Syslog Message
"The TLS connections have failed several times with remote host '%s' in IPspace '%s', for which the latest reason given is: %s."
- Parameters
peer (STRING): Network address of the remote peer.
ipsname (STRING): IPspace within which the network address is defined.
reason (STRING): Reason for failure.
