The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ha.takeoverimplowmem events
Creating your file...
Your file is ready
ha.takeoverImpLowMem
- Severity
ERROR
- Description
This message occurs when the partner node is down; however, due to this node being low on memory, it is currently impossible to perform a takeover.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Takeover of the partner node is impossible due to a low memory situation.
- Parameters
(None).
