clus.net events
Creating your file...
clus.net.noNeighbors
- Severity
ALERT
- Description
This message occurs when the cluster network ports with "link" reported as "up" are neither receiving CDP nor LLDP neighbor announcements. This is not a supported configuration and can negatively impact the performance of the cluster.
- Corrective Action
Use the "network port show -ipspace Cluster -link up" command to list the ports expected to receive CDP and/or LLDP announcements. Verify that CDP and/or LLDP is enabled on the switch the cluster ports are wired to. Use the "network device-discovery show" command to view the announcements for each of the cluster ports.
- Syslog Message
The cluster ports with "link" reported as "up" are neither receiving CDP nor LLDP neighbor announcements.
- Parameters
(None).
clus.net.switchlessInv
- Severity
NOTICE
- Description
This message occurs when the "switchless-cluster" option is disabled, but one or more cluster ports are directly wired to a cluster port on another node. This could result in packet loss across the cluster network, causing file operations to fail as well as loss of quorum.
- Corrective Action
Use the "network options switchless-cluster modify" command to enable support for switchless clusters.
- Syslog Message
One or more cluster ports are directly wired to a cluster port on another node, but the "switchless-cluster" option is not enabled.
- Parameters
(None).
clus.net.switchlessMismatch
- Severity
NOTICE
- Description
This message occurs when the "switchless-cluster" option is enabled, but all of the cluster ports are wired to a switch. This configuration will negatively impact the performance of the cluster network.
- Corrective Action
Use the "network options switchless-cluster modify" command to disable support for switchless clusters.
- Syslog Message
All of the cluster ports are wired to a switch, but the "switchless-cluster" option is enabled.
- Parameters
(None).
