The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mcc.kill events
Creating your file...
Your file is ready
mcc.kill.received
- Severity
INFORMATIONAL
- Description
This message occurs when the node is halting because it received a "kill" message from the disaster recovery (DR) partner.
- Corrective Action
(None).
- Syslog Message
Node is halting because a kill message with reason %s has been received from the DR partner with system ID %ld.
- Parameters
reason (STRING): Reason for halting the node.
sender_sysid (LONGINT): System ID of the sender.
